January 23, 2026, 06:52:57 pm
It's an excellent machine. Clean, neat, looks like it was CNC'd and then laminated to perfection. That's just paint on MDF?
May I ask what font you used for your lettering?
The speaker holes, using the round over bit, is that a 1/4 or 1/2 inch bit?
Is the speaker panel parallel with the ground, or at an angle? What is the height of the glass area (admin panel to speaker panel?)What radius (radii?) did you use for your corners on the side panels? They don't look as sharp as the "Woody" cab, but not too rounded either. I like that.What are the functions of your admin buttons? You have black ones I assume are some type of admin next to the start buttons on the CP, and 4 below the monitor.
So, you have had the cab for a couple years now, is it still working out for you? Anything you would do different?
