Author Topic: holesaw powerdrill question  (Read 2399 times)
noobofthecentury
  • Last login:April 15, 2008, 01:18:00 am
« on: March 30, 2008, 02:43:21 am »
I bought holesaws but the arbor does not fit my powerdrill
My power drill chuck is maxed at 3/8 inch
can some1 link me to a holesaw ( 1 1/8inch)
that will fit my powerdrill?
I look around but I am not sure about its size, I dont want to spend money buying the wrong ones again.
thx
sstorkel
  • Last login:November 08, 2011, 09:04:03 pm
Re: holesaw powerdrill question
« Reply #1 on: March 30, 2008, 12:00:17 pm »
Most holesaws use an arbor that will only fit a drill with a 1/2-inch chuck. Milwaukee sells an arbor that will fit a 3/8-inch chuck. IIRC, it only works with their smaller hole saws, though. If I were you, I'd try searching with Google or Amazon to find what you need.
In my case, I ended up buying a corded drill with a 1/2-inch chuck so I didn't have to worry about which arbor I was using...
noobofthecentury
« Reply #2 on: March 31, 2008, 03:23:19 am »
your reply made my day, thx
shardian
« Reply #3 on: April 02, 2008, 08:57:50 am »
Harbor freight has an el-cheapo hole saw kit that fits a 3/8 chuck. You are much better off using a spade bit, or a forstner bit though on CP holes. Both can be had relatively cheap at any hardware store.
RoninEditor
  • Last login:April 14, 2009, 02:46:58 am
« Reply #4 on: April 06, 2008, 12:18:29 am »
Noobofthecentury... save yourself a headache and buy yourself a 1 1/8" forstner bit... it's super clean and super accurate.  I found mine at OSH... Home Depot and Lowe's looking at me like I was speaking Russian.  Try real hardware stores for these.
Here's some general info about them:
http://www.ronhazelton.com/tips/forstner-drill-bit.htm
They fit any standard drill.
I'm only using a 3" hole saw for my trackball.
