Author Topic: where to get cap kit?  (Read 4676 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
« on: March 28, 2008, 08:36:48 am »
hi gonna replace the caps in my 20" monitor, but where do i get the cap kit from and  list of what caps to replace, or should i just replace all caps or test them 1st? the monitor is a 20" kortek ktx20 110v cga, the screen is dull , like faded so think a cap kit might fix it, was gonna put a tv in but i would just get same resolution,im in uk and could prob test them and replace the ones that dont measure up to the markings on the can, could get replacements from rs or maplin
Re: where to get cap kit?
« Reply #1 on: March 28, 2008, 09:23:25 am »
Or you could try the real Bob Roberts.
« Reply #2 on: March 28, 2008, 09:59:36 am »
If you get it from Bob, doublecheck the caps against both his list and the schematic.  Last two kits I got from him had too many that were wrong.  His list was right but the wrong caps were all half the proper voltage or worse.
ahofle
    • Arcade Ambience Project
« Reply #3 on: March 28, 2008, 10:29:19 am »
You could also try Zanen:
Zanen Electronics
46 Parklane Drive
Ransom Canyon, TX  79366
Tel: 888-449-2636
E-mail: zanenelectronics@aol.com
http://randyfromm.com/amusements/yellowpages/zanen/
« Reply #4 on: March 28, 2008, 10:40:28 am »
Zanen is good.  I recently called them looking for a Commodore 1084 kit.  He didn't have them so he ended up putting together a large "general cap kit" for me with 5-6 each of tons of different common monitor cap values.  Very very useful and the price was good.
G1zm0
« Reply #5 on: March 30, 2008, 06:17:55 am »
will try that as there is alot of caps to change ,i take it they need changed on neck board to? i was trying to get the schematic for my monitor but google dont through anything up,ill email bod and hop he posts to uk, well back to painting the cab :)
G1zm0
« Reply #6 on: March 30, 2008, 12:32:44 pm »
tryed bob roberts he doesnt ship to uk, so gonna try fuse 1st before cap kit
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #7 on: March 30, 2008, 06:41:10 pm »
Why are you replacing the fuse?  If it's blown, it's blown for a reason.
G1zm0
« Reply #8 on: March 31, 2008, 07:16:18 am »
its the logical place to start, i think, there is only 2 components after it,  ill meter the ac see if its correct voltage but the other 2 components (black square) i dont know how to test, any recomendations? dont want to put into tv shop would cost fortune
grantspain
« Reply #9 on: March 31, 2008, 07:33:11 am »
if the degauss circuit is not working you will have discolouration,the fuse blowing all the time points to either the ptc component(positor) being short circuit
or a short on the actual degauss coil
to prove its not the coil simply unplug it
to prove its not the ptc then you would need to desolder from the chassis
a ptc component costs about Ģ2
G1zm0
« Reply #10 on: March 31, 2008, 09:24:59 am »
thanx i think i will just buy one put it in and then try it and see if it blows, then i know the fault is elseware, im might as well buy one as i, goint to maplin to get the fuse anyway, wont hurt
G1zm0
« Reply #11 on: April 01, 2008, 05:07:47 am »
on the ptc component  on the board i cant find what value it is, all its got on top of it is pth45ic then under it says 02*8d (the* is a circle with a m in it) maplin dont do them, i found some sites with them but non for this chassie, also cant find the monitor spec sheet, any help locating this appreciated,if the coil is fuxored then its bin time, and use a tv instead for time beeing, got a few jamma boards, if i use tv with scart rgb is there a way to connect boards rgb out to it?
grantspain
« Reply #12 on: April 01, 2008, 11:04:44 am »
www.cpc.co.uk fot the positor
http://cpc.farnell.com/RE01467/components-spares/product.us0?sku=KONIG-PTC14740&_requestid=72714
donīt worry about the part number just make sure its the same shape and leg configuration
to use a scart t.v
http://forum.arcadecontrols.com/index.php?topic=77370.0
Ken Layton
  • Guru
  • Technician
« Reply #13 on: April 01, 2008, 11:38:53 am »
That's not a model number distributed in the USA.
G1zm0
« Reply #14 on: April 01, 2008, 11:45:52 am »
thanx for links, quite cheap for there components, pitty the goods come to 1.55 but Handling Charge is  Ģ5.95 , well suppose ill order it to try it
G1zm0
« Reply #15 on: April 01, 2008, 11:51:52 am »
hi sorry its a ktm20, that was typo, all so looked at getting a replacement degaussing coil in uk, tryed that site grant gave me but they no longer stock the 20" one quite cheap to only 2.50 or so
G1zm0
« Reply #16 on: April 02, 2008, 03:31:30 am »
hi grant that scart link ive already saw but the diagram is from pc to scart, i was on about jamma board to scart, ive got 3 jamma boards 2 konami(double pcb) and a jelico pcb, and havent a clue whats on them till my parts arrive i want to see if they work,as i only get a 7 day return guarantee if dead
grantspain
« Reply #17 on: April 02, 2008, 09:32:44 am »
G1zm0
« Reply #18 on: April 03, 2008, 04:29:41 am »
thanx for link, thats the puppy, atleast i can try these boards, now to get the connectors, ill try maplin
Level42
« Reply #19 on: April 03, 2008, 09:09:59 am »
You didn't read it completely obviously, as it ALSO covers real arcade PCB's to SCART...
