Author Topic: Linux Modeline +arcade monitor question  (Read 1717 times)
chessiv
  • Last login:October 16, 2017, 09:03:44 pm
    • My Arcade
« on: March 27, 2008, 11:41:38 pm »
I'm using an old 19" wellsgardner cga monitor hooked up to a pc.  I use a modeline in linux that works great to display a 6480x480 interlaced to the monitor.  Question is, during the pc bootup the card kicks out a "standard" 640x480 mode that makes the monitor go haywife until the modeline kicks in.  Any ideas on how to disable video linux starts up?
whammoed
  • Last login:March 13, 2026, 12:48:37 pm
  • Crack don't smoke itself
    • NiceMite
Re: Linux Modeline +arcade monitor question
« Reply #1 on: March 28, 2008, 09:23:54 am »
Are you wanting to disable the video during the bios post as well?  If so, your best bet may be to use a relay and have the monitor shut off until linux loads and you can use something like the parallel port to trigger the relay to turn on the monitor. (just a theory, have never done it)
What are you using as your boot loader?  Grub?
chessiv
    • My Arcade
« Reply #2 on: March 28, 2008, 12:07:40 pm »
Yes, I am using grub.
It would be ideal to turn off the bios video too.  I figured I would have to use external electronics but wanted to see if anyone had some clever ideas.
whammoed
    • NiceMite
« Reply #3 on: March 28, 2008, 02:21:32 pm »
Maybe see if you can do something like this guy did?:
http://www.wicksta.com/arcade/installation.php
