Author Topic: Are Medium Res monitors "backwards compatable" ?  (Read 3274 times)
Stobe
« on: March 23, 2008, 09:40:07 am »
As topic states:  can a med res monitor be used to display a standard res game?
Thanks.
Stobe
grantspain
Re: Are Medium Res monitors "backwards compatable" ?
« Reply #1 on: March 23, 2008, 09:45:51 am »
some monitors are dual sync,depends on your model number though
if its fixed med res then you would need some kind of converter and from what i have seen med res output converters are very pricey
Stobe
« Reply #2 on: March 23, 2008, 10:05:31 am »
darnit.  I was hoping for a simple yes/no answer.  This hobby has too many unknowns :)
-Stobe
northerngames
  • Trade Count: (+18)
« Reply #3 on: March 23, 2008, 10:13:44 am »
what type of monitor is in question or were you just wondering if they all were?
Stobe
« Reply #4 on: March 23, 2008, 10:18:17 am »
That's the problem.  I don't own it yet.  But its in a sega naomi cabinet, if that helps any?  (probably not, lol)
-Stobe
grantspain
« Reply #5 on: March 23, 2008, 11:27:07 am »
sega naomi standard monitors are sanwa 29es31 and nanao 2932 which are both high res 31khz
sega astro city have nanao ms8 variations 15/25khz
sega new astro city have nanao ms9 15/25khz
sometimes found in naomi cabs are multisync nanao ms2931
 you can see from this small choice the different type of monitors that can found
 if it is a sega naomi cab that is running a naomi mobo setup of any kind then it can only be a 31khz or 15khz monitor as naomi does not support 25khz
 if you find the game that is installed in the cab then you id the frequency
Stobe
« Reply #6 on: March 23, 2008, 11:31:22 am »
ok, its current;y running virtua tennis, and has some virtua golf burn-in on it.
Thanks so far for all the help!
-Stobe
grantspain
« Reply #7 on: March 23, 2008, 11:45:01 am »
31khz for sure,15khz to 31khz converters are cheap if you want to jamma games
Stobe
« Reply #8 on: March 23, 2008, 11:55:46 am »
Cool thanks.  Do you have a link to an example converter that would work good to play stand res jamma games in that cab?
grantspain
northerngames
« Reply #10 on: March 24, 2008, 12:05:50 am »
those are cool.
« Last Edit: March 24, 2008, 12:15:08 am by northerngames »
