Author Topic: Mike Tyson's Punch-Out!! - Playchoice10  (Read 1655 times)
WhiteComet
  • Last login:January 13, 2010, 04:22:21 pm
  • iD Project 2010
« on: March 23, 2008, 09:24:33 am »
Hi
Just wondering if this is a board problem or a battery problem!
Once you beat the first boxer (glass joe) the game crashes!!!
This is the only board that has a CR2023 battery on (havent replaced it) but could this be the fault? as it has data-entry option?
Or is it purely the board is broken!? all the fuses etc.. seem to be on the board!?!
any help?
H T T P : / / W W W . I N I T I A L D O N L I N E . C O M
2600
Re: Mike Tyson's Punch-Out!! - Playchoice10
« Reply #1 on: March 24, 2008, 08:47:57 am »
Is this the only game causing you problems?
Have you tried a different slot?
Have you verified the EEPROMS?
I'm not sure when the security part takes place, but I suppose the security chip could be going bad.
WhiteComet
  • iD Project 2010
« Reply #2 on: March 25, 2008, 03:53:52 pm »
hi thanks for the reply...
yh tried it in a different slot.
the game use to work fine before!
not sure how to verify a EEROMS  :dizzy:
going to replace the battery soon though!
