March 01, 2026, 02:17:37 pm
this is a monochrome vector monitor.
Well I have a WG U2000, When I first turned it on I have a 3 inch spread of picture from left to right (horizontally,no top and bottom) across the screen and couldnt adjust it out. I bought and installed the WG Vertical Sweep Kit, and now I just have the same 3 inches but its all green now and I cant see any part of the picture. Should I remove the vert kit and try the U5000's horizontal kit? Do you think the power supply update kit could fix this?Any thoughts as to what to do now?
I did notice a small descrepancy in the vert kit. The top of the page says to use a 100uf 35v cap, and in the directions it says to use a 100uf 50v cap. The kit came with a 35v one so thats what I used. The one that was previously installed was a 50v.
