Author Topic: Bat top replacement for Suzo 500  (Read 1394 times)
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
« on: March 21, 2008, 06:48:57 pm »
A friend of mine loves Suzos 500 but he prefers traditional bat tops. Is there any replacement shaft that he could use, or any shaft from any stick by Industrias Lorenzo that could be compatible?
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Re: Bat top replacement for Suzo 500
« Reply #1 on: March 21, 2008, 07:03:16 pm »
cut balltop
make the thread of a screw, "reverse" this video
[youtube]http://youtube.com/watch?v=Wzukaqymi9w[/youtube]
and buy LB30N (sanwa battop)
Grasshopper
« Reply #2 on: March 21, 2008, 08:41:27 pm »
The IL shafts and the Suzo shafts are both 10mm in diameter. So theoretically you should be able make an IL shaft compatible with a Suzo base simply by cutting a groove into the appropriate position. I'd suggest having a word with Franco B to see whether he can do anything for you.
http://forum.arcadecontrols.com/index.php?action=pm;sa=send;u=15346
