Author Topic: Happ's 3" trackball grounding  (Read 2579 times)
QuarterJunkie
  • Last login:August 19, 2020, 11:01:27 am
« on: March 17, 2008, 09:14:16 am »
I'm finishing up wiring my control panel and had a question regarding grounding of the trackball. I notice that there are 2 fairly heavy guage ground wires coming off the trackball. Is it ok to ground these to the GND connection on my Ipac (tie in with my button grounds), or should they be wired directly to the pc chassis (or the ground wire from the power supply)? I'm just curious because of the guage of the wire. Is there too much current drain for the Ipac to handle?
Minwah
    • MAMEWAH
Re: Happ's 3" trackball grounding
« Reply #1 on: March 17, 2008, 10:29:48 am »
I would connect this to the mains earth connection rather than the IPAC.
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
« Reply #2 on: March 17, 2008, 10:31:12 am »
And, for my stupid brain, where, exactly would this mains earth connection be?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« Reply #3 on: March 17, 2008, 12:26:54 pm »
That is the ground from the main power cord powering up your arcade.
It depends how you have your power connected to your unit.
I wonder if that is why my Happ boards blew out?
I had mine grounded to my Ipac.
Half of the people you meet are below average.
TOK
  • The Game Always Wins
« Reply #4 on: March 17, 2008, 12:53:01 pm »
I don't think that blew out your boards... I ran a lead from the ground on my IPAC to a lug, then routed all my button and trackball grounds to it. That system has been up and running for about 4 years. I think the ground on the ball is primarily a static ground.
QuarterJunkie
« Reply #5 on: March 17, 2008, 02:33:03 pm »
Oh. Alright. If it is for static, I'll just run a wire to a case screw on the pc.
fatfingers
  • Got UltraStiks?™
« Reply #6 on: March 17, 2008, 03:28:47 pm »
So, won't the case be charged then?  Or is that all somehow grounded to "mains"?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
QuarterJunkie
« Reply #7 on: March 17, 2008, 03:46:02 pm »
The case should be grounded through the electrical outlet (asuming it is a metal case)...Otherwise, you could also ground it to a ground wire from a power supply (either of the 2 middle black wires) molex connector.
2600
« Reply #8 on: March 17, 2008, 04:11:16 pm »
No, they are not the same ground.  Do not do that.
Screw it onto the case screw that attaches to the power supply.  Internally, the power supply connects the case to earth gnd coming from the outlet.
mountain
  • Last login:January 29, 2025, 08:31:47 am
    • Mountain Jukeboxes
« Reply #9 on: March 17, 2008, 06:08:27 pm »
The two middle pins on the Molex connector, the case, the input ground pin where your AC plugs into the power supply, they are all tied together. Do what is easiest, probably connecting it to the output of the power supply is the most common.
