Author Topic: Nec multi sync crt monitor question  (Read 2587 times)
rrcade
  • Last login:December 03, 2019, 10:37:08 pm
« on: March 16, 2008, 02:02:11 pm »
Just picked this up for a mame, I don't know much about monitors, question is if this is multisync does that mean it will handle various mame resolutions or do I still need AVGA card to get proper res.?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Nec multi sync crt monitor question
« Reply #1 on: March 16, 2008, 02:36:02 pm »
multi sync means it can process several different scan frequencies and thus, differing resolutions.
qrz
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #2 on: March 17, 2008, 06:42:27 am »
All normal PC monitors are "multisync" - but that does not mean they are any good for mame/AVGA use.
What you actually need to know is the input specifications of your exact monitor.
NEC made totally normal PC monitors called "Multisync" which will not work with an AVGA's arcade modes. NEC also made some rather impressive  presentation monitors that support all known arcade video modes natively. Not all there presentation monitors are the same though. Some will support 15Khz/24Khz/31Khz. Others just 15Khz/31Khz.
Whats the model number of the monitor?
rrcade
« Reply #3 on: March 17, 2008, 05:40:34 pm »
It's a NEC multisync E1100+  21"crt monitor.
ahofle
    • Arcade Ambience Project
« Reply #4 on: March 17, 2008, 06:03:42 pm »
Synchronisation Range (Automatic) Horizontal: 31 kHz to 96 kHz
So that will only go down to 640x480 and hence will not handle CGA or even EGA arcade resolutions.  You don't need an ArcadeVGA in other words (you will have to just run everything at a higher resolution and have MAME scale it).
Ummon
  • Trade Count: (+13)
« Reply #5 on: March 17, 2008, 08:08:17 pm »
Attached is, very probably, the Killer List of video displays.
« Last Edit: March 19, 2008, 09:54:25 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
