Author Topic: Question about soft15kHz and connection to arcade monitor  (Read 1137 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: March 14, 2008, 01:17:46 pm »
Hey all!
In the near future I will be using soft15kHz so I can output 15kHz to my arcade monitor.
But I am puzzled by how to do this....the gfx card outputs in VGA(RGBHV) and arcademonitors use RGBS...how
I should I get HV-sync to single-lead sync?
Any advice is welcome! I need to get this working :)
Thanks,
Nicholas
ahofle
    • Arcade Ambience Project
Re: Question about soft15kHz and connection to arcade monitor
« Reply #1 on: March 14, 2008, 02:05:25 pm »
It's called "composite" sync.  You would just tie together the H and V sync into the one sync wire that leads to your arcade monitor.  Just make sure that's what your arcade monitor requires (some support composite and some support separate H and V sync).
