Author Topic: LEDBlinky + PacDrive, No PacDrive in Device list?  (Read 2378 times)
Franco B
« on: March 14, 2008, 09:14:13 am »
Ive had LEDBlinky working fine with three LED Wiz's. I recived a PacDrive the other day and ive just wired up some cathodes etc to it and I now want to program some sequences.
As with the LED Wiz's you have to generate the Input Map from the utility in the LEDBlinky Tools tab within the Configure LEDBlinky application.
My problem is that there does not seem to be an option to select the PacDrive.
The documentation from Ultimarc shows this screen with the PacDrive being selected from the Device drop down tab:
However, when I run the utility the same drop down tab is named LEDWiz ID and there does not seem to be an option to select a PacDrive:
I have connected the PacDrive to the computer and it has been dected prior to this.
Surely im missing something really simple here?
headkaze
  • 0x2b|~0x2b?
Re: LEDBlinky + PacDrive, No PacDrive in Device list?
« Reply #1 on: March 14, 2008, 09:26:35 am »
Franco B
« Reply #2 on: March 14, 2008, 01:16:50 pm »
Thanks mate, I knew it would be something simple :)
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #3 on: March 14, 2008, 03:50:01 pm »
Robots will kill you.
Arcade Addiction
