Author Topic: Need Help Removing DK Jr Bezel  (Read 1056 times)
barrel_hopper
  • Last login:April 18, 2013, 01:53:28 am
« on: March 13, 2008, 05:50:35 pm »
Hey guys I cant seem to figure this out...I loosen the wingnuts on the bezel retainer bar and I cant seem to figure out what else is holding the bezel in place. It is hard to reach in the machine and blind feel around for anything else. Getting the marquee off is no problem
If someone could describe the procedure to me that would be awesome. I really need to get the bezel off for a cleaning on the backside and I need to make a new monitor bezel from paper.
Thanks in advance guys.
Adam S.
Jeff AMN
    • Gamer Theory
Re: Need Help Removing DK Jr Bezel
« Reply #1 on: March 13, 2008, 06:08:16 pm »
You have to slide it up and out (away from the cab), if it's anything like my DK machine. Mine also had a bit of hot glue gun glue making things iffy. With a bit of wiggling, I got it out, cleaned up the glue, and now I can take out off and put it on as needed.
At the bottom of your bezel, is there a thin piece of black metal? Use that as a handle to lift up, if it's there.
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
« Reply #2 on: March 14, 2008, 02:26:17 pm »
You have the first part correct, loosen the retainer and slide the retainer back away from the bezel, then the bezel has enough slop on the top to lift it up and forward.  If you are missing the black bar at the bottom of the bezel, you'll need to slide it up and catch the bottom with something, like a flat blade screwdriver to move it out and forward.  Here is the instructions from the manual for removing the bezel.
 - Mike -
