Author Topic: Need custom bezel artwork  (Read 1949 times)
sacolton
  • Last login:May 09, 2008, 04:33:06 pm
« on: March 12, 2008, 01:40:31 pm »
I have a Berzerk bezel that I need to replace with something that matches my
cabinet theme.  I purchased a marquee that looks like this:
Now, I'd like to find a bezel with a similar style with the PacMan/MsPacMan
mazes merged in the middle - and a 19" center cutout for the monitor.
Can anyone help me with this?
- sacolton
Luigi
  • Collecting/restoring cabs
Re: Need custom bezel artwork
« Reply #1 on: April 22, 2008, 08:52:01 am »
Hi.
I've sent you a PM.....this is what I've done for you so far :) I took a standard Pac Man screenshot and used that maze for the bezel. Want any changes? Just tell me.
If needed I can turn (and of course resize) the monitor cut.
The size and position of "ARCADE" can be changed in any way you want.....I've vectorized all stuff so that's no problem. It can be positioned completely inside the frame so you don't have to cut the print.
« Last Edit: April 22, 2008, 08:56:08 am by Luigi »
Luigi
« Reply #2 on: May 08, 2008, 09:47:02 am »
"Thanks" for not replying  :badmood:
gonzojoey
  • Last login:August 30, 2020, 10:26:44 am
« Reply #3 on: May 08, 2008, 02:39:18 pm »
Well, I liked it  ;D
If you don't mind, I might actually use this once I get to my Ms Pac "restore"...once I decide if I want to stay completely stock or maybe change it up a bit. But it'll be a while before I get to that cabinet. I have 3 others in line before my Ms Pac (too many projects, not enough time  ::) )
Luigi
« Reply #4 on: May 09, 2008, 02:52:35 am »
Meanwhile I changed the colors from pink to the colors used in Ms. Pac Man.
I can upload the vector file if you like. Just let me know...and the format (Corel, AI, PDF)
At least no wasted time at all :)
