Author Topic: SlikStik Tornado question  (Read 9315 times)
metaHipster
  • Last login:January 10, 2010, 06:09:19 pm
  • Taking the next level to the next level
    • MetaHipster's Arcade Blog
« on: March 11, 2008, 07:25:33 am »
Just got my first SlikStik Tornado spinner - they seem well rated but upon receiving mine, I've noticed that the bottom of the weighted cylinder rubs on the metal ring on the bottom part.  Is this normal?  I can put a slight upward pressure on the axle from below and separate the cylinder from the ring and it spins forever but if I just let it be it rubs and has almost no momentum to it.  I put a bit of 3 in 1 oil on it which makes it better but it almost seems as though the bearings aren't giving it much benefit.
Just wondering if I need to arrange an exchange or if this is normal.
-Matt
patrickl
  • Yo momma llama
    • PocketGalaga
Re: SlikStik Tornado question
« Reply #1 on: March 11, 2008, 07:30:09 am »
Mine has a ring between the bottom (bearing) and the cylinder.
stones
  • Last login:November 16, 2008, 12:22:00 pm
    • Mission:Arcade Blog
« Reply #2 on: March 12, 2008, 01:49:31 am »
I received two (one and then a replacement) and both had the same problems (worked fine upside down, right side up they had heavy, unplayable friction). Do what I did, send it back, get your money back and request they take another look at how they're manufacturing them (they now recognize the problem, and hopefully will fix it).
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #3 on: March 12, 2008, 03:47:49 am »
SlikStik is out of business.
If you bought it from another vendor you might try getting your money back.
stones
« Reply #4 on: March 12, 2008, 11:48:24 am »
Slikstik may be out of business, but Happ still manufactures fresh ones (albeit badly).
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #5 on: March 12, 2008, 11:53:16 am »
happ does not make these spinners they were ordering them from slikstik direct
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
metaHipster
« Reply #6 on: March 12, 2008, 01:26:53 pm »
thanks everyone.  At $70 I'm not going to keep it if it's gonna have this much friction.  I'll return to HAPP.
The EZ Arcade spinner I have seems to be a good bang for the buck (under $40!) so maybe i'll pick up another of those.
Note that the SlikStik tornado knobs fit on the EZ Arcade spinner (the metal knob I got from EZ Arcade was craptastic -- looked like a cheap volume knob from radioshack).
If anyone wants to suggest any other spinner options, I'm open to hearing them.  Seems like quality spinner manufacturers just aren't sticking around... First Oscar, now SlikStik....
divemaster127
« Reply #7 on: March 12, 2008, 01:29:35 pm »
Right now the options are the ulitmarc spintrak the slikstik spinner tops fits these & the GGG spinner, apache has one but its $$$
  • Last login:Today at 05:14:12 pm
    • GroovyGameGear.com
« Reply #8 on: March 12, 2008, 02:47:24 pm »
Do a search on "TT2" or "TurboTwist 2"   ;)
« Last Edit: March 12, 2008, 03:02:50 pm by RandyT »
stan2323
  • Last login:January 13, 2023, 06:05:19 pm
  • Major Retired USS Enterprise Commanding
    • My home page
« Reply #9 on: March 12, 2008, 08:18:58 pm »
Has anyone used the Apache?  How is it? Does it have a "energy storage cylinder" option?
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
« Reply #10 on: March 12, 2008, 09:42:06 pm »
I got one of these from Happ also.  It was assembled incorrectly.  The shaft was upside down, no e-clip on the end, the o-ring is too small to sit on the bottom bearing.  Once I took it apart and put it back together correctly it works very well.  Oh, I added a small 1/4" flat-washer between the rubber o-ring on the bottom and the large weight the encoder mounts to, this raises up the counter-weight off the bottom bearing housing.  Not sure what they were thinking.
My corrected assemble is attached.
 - Mike -
stones
« Reply #11 on: March 12, 2008, 11:26:38 pm »
Happ has told me the contrary, but either way, Slikstik company or no, they're made to order and readily available. It's just a shame they're all made incorrectly.
stones
« Reply #12 on: March 13, 2008, 02:46:43 am »
pcb: Nicely done sir.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #13 on: March 13, 2008, 04:11:17 am »
Yeah, that they assembled the thing wrong could be the problem too. Either way there has to be a small ring on the bottom. You might be able to put one there yourself if you can find one.
To be honest I didn't like the Tornado spinner that much. I like Arkanoid and the tornado spinner doesn't really work well for that. It doesn't have the necessary resolution (ie you need to spin the spinner too much to move the bat) I bought the Spintrak and that works a lot better.
genesim
  • Last login:April 12, 2010, 08:18:42 pm
« Reply #14 on: March 13, 2008, 04:31:03 am »
I second the Spintrak and it uses the same tops as the Tornado.   Quality all around!
metaHipster
« Reply #15 on: March 18, 2008, 09:14:44 am »
pcb: thanks!
I've mentioned the problem to Happ Controls and IMMEDIATELY got a human response offering a replacement shipment with prepaid return shipping!  That's what I call service!   We'll see if the next one has the same problem and if so, I'll use pcb's trick with washer and verifying axle orientation.
It spun amazingly smooth when the weight wasn't on the bearing housing so anything that minimizes that should fix it.  I was even picturing some spring/coat hanger attachment to put a single point of upward pressure on the bottom of the axle beneath the bottom frame since just pushing up with my finger made it spin like a champ :)  Your solution seems far simpler and less prone to slipping.  Weird they're not putting these together properly.
metaHipster
« Reply #16 on: March 18, 2008, 09:29:47 am »
have you tried messing with the mame analog settings? (tab-menu)  Seems it usually defaults pretty low and should be able to go up to 200 i think.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #17 on: March 18, 2008, 11:23:34 am »
The sensor wheel just doesn't have enough teeth to work properly in "high resolution spinner" games like Arkanoid.
pcb
    • MikesArcade.com
« Reply #18 on: March 18, 2008, 12:09:45 pm »
pcb: thanks!
No Problem, I had emailed the same picture to Happ and got a very cryptic response back.  Hopefully they have the assembly correct now, using a slightly bigger, fatter o-ring, which would eliminate the washer.
 - Mike -
