Author Topic: infiltrating my joust cabinet...  (Read 4228 times)
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« on: March 05, 2008, 10:19:07 pm »
so i just got a hold of my first real cabinet...an upright joust...!
i want to tweak the sticks and buttons & am having trouble getting the cp open...
i can undo the cp latches and when i try to pull the cp forward...the bottom of the glass bezel wants to come with it...kind of like it's connected...
does anyone have any ideas on what is going on...?
thanks...
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
Re: infiltrating my joust cabinet...
« Reply #1 on: March 05, 2008, 10:23:38 pm »
Ooo, look carefully at the edge where the CP meets the bezel; on my cab, it had a strip of thin foam (like weatherstripping) and was stuck to the plexi.
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
« Reply #2 on: March 06, 2008, 03:49:48 pm »
Yeah, what TelcoLou said :) I have a former Robotron cabinet and it's set up the same way, although mine is missing the foam (I can see where it would come in handy, to help cushion the CP against the glass). I imagine someone probably spilled some soda or something sticky in there at one time and made it stick to the glass. Actually, I may get a small piece of foam and put it in there so the wood isn't up against the glass. I'm sometimes a little concerned when I'm playing an intense game ;)
Paul Olson
    • Paul's Arcade
« Reply #3 on: March 06, 2008, 05:21:45 pm »
Not sure how to help with your problem, but would you mind posting some pics of how the sticks are mounted when you get it open. I found a pair on eBay and I am not sure how to install them. I am installing them in wood, but I would still like to see how they were done originally.
Thanks,
Paul
fixedpigs
« Reply #4 on: March 06, 2008, 09:26:20 pm »
i took a credit card and slid it in between the cp and the glass and worked it loose...
victory...!!
thanks for the help...
i'll try and get some photographs in the next few days...
fixedpigs
« Reply #5 on: March 08, 2008, 10:03:18 pm »
Thanks,
Paul
here are some blurry photographs...!
let me know if you want more clear ones...although i think these should give you a good idea of what you're after...
spacies
« Reply #6 on: March 09, 2008, 01:06:14 am »
Congrats on a great score.
Joust is a very cool game and a very nice cabinet.
fixedpigs
« Reply #7 on: March 09, 2008, 10:20:49 am »
thanks...!
here's a photograph of the cabinet itself...
i just need to replace the p1/p2 bulbs and the marquee light...maybe find a joystick rebuild kit...but i just set my newest highscore yesterday on it with 164,950...so the controls aren't so bad... 8)
Level42
« Reply #8 on: March 09, 2008, 02:53:28 pm »
Very very nice !
One of my favorite games.......congrats ! :D
spacies
« Reply #9 on: March 09, 2008, 08:02:10 pm »
thanks...!
Beautiful!
fixedpigs
my joust cabinet...
« Reply #10 on: March 11, 2008, 11:24:04 pm »
what is this...!?
inside my coin door...there is a leaf switch with a weight on it...
does anyone know what the purpose of it is...?
it almost looks like it'd be some sort of tilt switch or something...
and...
i replaced the player one & two button bulbs with some 12v automotive bulbs...they are really dim...are arcade cabinets 6v...?
thanks...!
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« Reply #11 on: March 12, 2008, 07:29:09 pm »
The switch is a slam switch.
Voltage on my joust at the bulb is 6.65 v ac.
I have #47 bulbs in mine and they burn nice and bright....
fixedpigs
« Reply #12 on: March 12, 2008, 09:30:08 pm »
so what is the purpose of a slam switch...?
cw
    • The Cab
« Reply #13 on: March 12, 2008, 09:35:38 pm »
Its to keep people from beating on the game..and on some games you could get a credit if you hit the coin door in the right spot.
fixedpigs
« Reply #14 on: March 12, 2008, 09:47:23 pm »
so does it reset the game or something if activated...?
it didn't seem to do anything when i was messing with it yesterday...
thanks for the info by the way...
cw
    • The Cab
« Reply #15 on: March 12, 2008, 09:53:10 pm »
i dont think that its hooked up for joust.... I will double check in a few
« Last Edit: March 12, 2008, 09:56:25 pm by cw »
cw
    • The Cab
« Reply #16 on: March 12, 2008, 09:58:18 pm »
The schematic shows it hooked up via the white and violet.  I checked mine and its not working but hooked up
