Author Topic: MameWAH not generating ZSNES list  (Read 1890 times)
Ginsu Victim
  • Comanche, OK -- USA
« on: March 02, 2008, 10:40:07 am »
Using MameWAH v1.62b13
No matter what I try I can't get it to generate a list for ZSNES. I've looked through topics about it here and at the ArcadeOS/MameWAH boards, but nothing has helped. Any help would be appreciated.
Here's my zsnes.ini
### zsnes.ini (mamewah v1.62) ###
emulator_title                            SuperNintendo
### List Generation Settings ###
rom_path                                  e:
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder_subfolders
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      c:\ZSNES\zsnesw.exe "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       c:\zsnes\snaps
movie_preview_path
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
« Last Edit: March 03, 2008, 08:19:42 am by GinsuVictim »
mccoy178
  • Go Bucks!
Re: MameWAH not generating ZSNES list
« Reply #1 on: March 02, 2008, 12:01:29 pm »
Your roms are in the "e" drive and not in a folder on the "e" drive?  I would make sure that file path is correct to your rom folder.
Ginsu Victim
« Reply #2 on: March 02, 2008, 12:04:54 pm »
I set it to look in rom_folder_subfolders. The roms are in lettered folders. (A B C etc)
However, even when I had it pointed to a folder of roms on my hard drive and had the path correct and set to rom_folder, it still wouldn't generate a list.
Ginsu Victim
« Reply #3 on: March 02, 2008, 12:09:22 pm »
I just tried pointing it at just one of the letter folders on the disc and it would saying generating list, then come up with nothing.
My roms are in zip format, so that's correct.
I don't know what the deal is...
gonzo90017
« Reply #4 on: March 02, 2008, 12:30:53 pm »
Make sure you're using the latest version. Mamewah_v162b13a.zip. Version 1.62b13 has some list generation problems.
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
« Reply #5 on: March 02, 2008, 12:33:30 pm »
I was having this same problem and switching to the latest version b13a fixed it
Ginsu Victim
« Reply #6 on: March 02, 2008, 01:00:25 pm »
I heard you needed the latest version, so I got it straight from the mamewah page. Guess it wasn't the latest. I'll try this one. Thanks for the link.
Ginsu Victim
« Reply #7 on: March 02, 2008, 01:15:02 pm »
Thanks! That fixed it. I just had the wrong version.
northerngames
  • Trade Count: (+18)
« Reply #8 on: March 02, 2008, 05:55:57 pm »
it would have worked in your old version also I noticed your rom extension was something other then zip and you stated later your roms were zipped so whatever you had there on the intitial post is more then likely why it was not working.
it could not find the roms so it could not make a list even if you have the right folder your rom extension name was wrong. :cheers:
Ginsu Victim
« Reply #9 on: March 03, 2008, 08:19:21 am »
The SMC was left in by mistake. I tried it with a folder of unzipped roms as well. Trust me, it was ZIP the rest of the time.
The reason it wasn't working was the version.
