Author Topic: Kortek Neo-Geo chassis, working after power supply looked at  (Read 4241 times)
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« on: February 22, 2008, 10:10:36 am »
Hi guys, just picked this Neo-Geo machine up and the guy said "don't work"... the usual.
I smoke tested the thing and the monitor came up like the flyback was turned up too high, kinda white, so I knew the monitor would probably function.  The game board had no games but the test pattern stuff should come up.... didn't.  So I started dissassembly.
This machine was located in a beach hotel or something.  Power supply totally shot.  I rigged up an ATX computer supply to power the board and the thing WORKS!!!!
The monitor does need a cap kit but I cannot determine the chassis.  Here are some pics...
It is connected to a Zenith tube with the number G-A63ADG25X and 04RC0105-009.
So, anyone recognize this chassis?
Or any insight into the "best" Neo-Geo games?
« Last Edit: March 15, 2008, 06:15:48 pm by Lutus »
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
Lutus
Re: Unknown chassis in Neo-Geo cabinet
« Reply #1 on: February 22, 2008, 10:25:43 am »
attaching pics for easier viewing
EDIT:  I know I need to invest in a compressed air can.   ;)
  • Last login:February 09, 2026, 10:26:35 am
« Reply #2 on: February 22, 2008, 10:32:01 am »
Don't know about the chassis, but there are some great fighters for Neo-Geo, IMHO.  Samurai Showdown IV, Garou, etc.  Metal Slug games can be fun as well.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: February 22, 2008, 11:41:53 am »
Looks like a Kortek monitor made for Sharp Image. Something like a SI-325 model maybe.
Lutus
« Reply #4 on: February 24, 2008, 11:03:44 pm »
I finally got the monitor out of the machine.  Some moron had locked his coin box closed with a bar and then lost the key to the padlock.  Thankfully I had a lockpick set handy, 10 seconds with a rake pick and it was all over.   :laugh2:
Removed the heavy monitor and can confirm that the chassis is a Kortek.  Will post a CLEAN picture tomorrow evening sometime.
Does anyone have any manuals of Kortek chassis that I can download since this one did not come in the cab?
Is there a common place on the PCB that will have the model stamped on it. Can't find one anywhere.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: February 24, 2008, 11:27:10 pm »
Try these:
http://www.2coinsperplay.com/Tech/Monitors/Kortek%20HTML/Kortek.htm
http://www.casinotech.com/TechDox.html
Kortek monitors generally have model numbers starting with "KT".
« Last Edit: February 24, 2008, 11:28:47 pm by Ken Layton »
Lutus
« Reply #6 on: February 25, 2008, 08:42:48 am »
Hopefully these images will help us narrow it down some...
grantspain
Re: Unknown chassis Neo-Geo - UPDATE: Kortek chassis
« Reply #7 on: February 25, 2008, 09:51:29 am »
here is an exact chassis(mirror imaged) made by sharp image with some interesting comments in the answers link
http://therealbobroberts.net/monitor78.html
Lutus
« Reply #8 on: February 25, 2008, 11:04:05 am »
Thats the one!   :notworthy:
I overlooked this thing at least twice due to the fact that the adjustments knobs are shown on the board on bobroberts website whereas mine are on an extension cable.
I will clean the board up, send bob roberts the pics for this chassis and try to get a cap kit and flyback.
Any other parts I should look at replacing while I am at it?
EDIT:  I double checked the IC's and they are the same number as bob mentioned in his write up.
grantspain
« Reply #9 on: February 25, 2008, 12:46:07 pm »
if the picture is good i would not bother to do any work on the monitor,dunno why you want to change the flyback-caps yeah maybe if you have some concern over the age but the flyback i would leave unless its arcing
Lutus
« Reply #10 on: February 25, 2008, 01:53:04 pm »
Now that I have that honking monitor out I have to order a cap kit for my other monitor (flyback for arcing) I may as well replace the caps while it is out.
I also just touched up some suspect solder joints that looked like early cracking.  Someone (previous owner) has already done some solder touchup around the flyback looks like.
Lutus
« Reply #11 on: February 26, 2008, 11:43:41 am »
I am in contact with Bob Roberts currently about the cap kit possibility.
Eventually I will make a post in Project Announcements about this machine but was just getting excited and wanted to say that I had ordered a new CPO from Mamemarquees.
Still need to buy new joysticks and buttons as these have been abused.
Lutus
« Reply #12 on: February 26, 2008, 10:49:06 pm »
Well, no cap kit so I put the monitor back in and now have two cartridges "Aero Fighters 2" and "Samurai Shodown".
After cleaning a couple layers of dirt and grim of the monitor and using my computer power supply to power the game board.... she is alive.
Will post pictures tomorrow, but for now I won't need a cap kit.  It is very workable.
Lutus
« Reply #13 on: March 15, 2008, 06:15:14 pm »
Alright,
Ordered a power supply and got a new CPO in from mamemarquees but haven't installed it yet because I am flattening it out.
Oh, yeah, those are also all new joysticks and buttons.
