Author Topic: Space Duel  (Read 1690 times)
paigeoliver
  • Awesome face!
Space Duel
« on: May 20, 2003, 12:18:18 pm »
I am having a lot of problems getting vector games to run at the correct speed at high resolution.
Space Duel only runs at 35-37 frames per second at 1600x1200 unless I turn off "Throttle", then it runs at 140-190.
What can I do to make it run at the correct speed?
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
Re:Space Duel
« Reply #1 on: May 20, 2003, 12:40:28 pm »
this might be bad advice but have you tried ticking the "match game refresh rate" box?
paigeoliver
  • Awesome face!
Re:Space Duel
« Reply #2 on: May 20, 2003, 12:48:01 pm »
Yes. I tried that box. No effect. Still runs like a demon if throttle is off, and runs too slow if it is on.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Space Duel
« Reply #3 on: May 20, 2003, 06:00:07 pm »
ever try creating a vector.ini file and setting the resolution to 640x480.  That's what I do.
paigeoliver
  • Awesome face!
Re:Space Duel
« Reply #4 on: May 21, 2003, 12:24:49 am »
640x480 through 1024x768 works just fine. But vectors look awesome at 1600x1200. I just can't get most of them to run the proper speed at that res (Star Wars and ESB will, but none of the others will).
