Author Topic: Why does it chirp?  (Read 1663 times)
Ummon
  • Trade Count: (+13)
Why does it chirp?
« on: February 18, 2008, 09:31:31 pm »
I read somewhere here that a bad cap(s) in the power section can cause a chirping sound when the monitor is powered up. Is it the cap chirping?
Yo. Chocolate.
Stephen Hawking
grantspain
Re: Why does it chirp?
« Reply #1 on: February 19, 2008, 06:41:57 pm »
it chirps because its trying to start up but can't,caps can cause it but so can many other things.i prefer to call it "in trip"
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: February 21, 2008, 07:59:16 pm »
many switch mode power supplies will briefly chirp on initial power up .
if the supply exhibits excess noise ( hiss/chirps) during changes in load , there may be weak 'lytics.
still best to measure Dc voltages and for presence of AC ripple ( pulses )
a squealing smps has a strong likelihood of a heavy load (short) on a secondary .....
qrz
Ummon
« Reply #3 on: February 23, 2008, 01:01:25 pm »
It's a constant chirp. The monitor won't display.
Yo. Chocolate.
Stephen Hawking
qrz
« Reply #4 on: February 23, 2008, 04:06:57 pm »
check the secondaries for a high load. it may not be a dead short , but enough to keep supply from starting .
in tv's , a  faulty vert output ic is a common culprit.....
qrz
