Author Topic: Brightness pot question  (Read 1388 times)
« on: February 09, 2008, 05:35:17 pm »
I'm still working on this XM501... tried the rejuvinator, didn't do anything.  I was poking at the controls and noticed that the brightness pot seems to do nothing.  The rest all show a response.  I haven't found any spots where it is visibly removed from the circuit.
The schematic lists it as a 200k resistor, R21 as shown below.  When I turn it all the way down resistance reads as 5ohms.  All the way up - 132k.  I don't see how to tell from the schematic what the low reading should be but can I assume that 132k isn't enough at max and that this thing should be replaced?
FWIW, I can tone it to R22.
« Last Edit: February 09, 2008, 05:48:51 pm by ChadTower »
Ken Layton
  • Guru
  • Technician
Re: Brightness pot question
« Reply #1 on: February 09, 2008, 07:10:40 pm »
You're getting false readings because of other components in the circuit.
You need to temporarily unsolder all wires going to that pot in order to test it accurately.
« Reply #2 on: February 09, 2008, 09:10:06 pm »
I was afraid of that.
It was brought up in my project thread, and I have thought of this but didn't understand enough to consider it fully, but would the signal from a VCR be displayed as dim, and thus maybe I have a good monitor that I'm still trying to fix?  I have been considering that maybe the signal from the VCR isn't strong enough to be bright on the monitor.
EDIT:  out of circuit it tests to 175k fully open.  Good enough or should I replace it?
« Last Edit: February 09, 2008, 09:41:17 pm by ChadTower »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #3 on: February 09, 2008, 10:02:28 pm »
since turning the ctl is producing no effect , also suggest verifing 150 v source ,  check r95, r22, then check c10 and q21 for  possible shorts ....
qrz
