Author Topic: Tekken tag standard res or medium?  (Read 2766 times)
berlincam86
  • Last login:January 30, 2020, 10:03:28 am
  • I can't wait to build my first cabinet!
« on: February 05, 2008, 06:18:34 pm »
Just wondering if someone knows. KlOV says medium but Im not sure its right.
« Last Edit: February 05, 2008, 06:32:33 pm by berlincam86 »
ahofle
    • Arcade Ambience Project
Re: Tekken tag standard res or medium?
« Reply #1 on: February 06, 2008, 04:55:51 pm »
Neither according to MAWS.  It's VGA (640x480).
http://www.mameworld.net/maws/romset/tektagtc
berlincam86
« Reply #2 on: February 06, 2008, 04:59:13 pm »
ok does anyone know where i can get a copy or picture of the move list?
« Reply #3 on: February 07, 2008, 12:35:05 am »
game faqs + photoshop?
Xiaou2
  • Last login:Yesterday at 07:34:42 pm
  • NOM NOM NOM
« Reply #4 on: February 07, 2008, 02:41:22 am »
 I know Tekken III  and some other Namco games have an option for
Interlace mode in the service menu.
berlincam86
« Reply #5 on: February 07, 2008, 09:29:36 am »
whats game faqs? And whats interlacing?
ahofle
« Reply #6 on: February 07, 2008, 09:14:37 pm »
Ahh, maybe it supports both CGA and VGA monitors then.
berlincam86
« Reply #7 on: February 07, 2008, 09:20:49 pm »
Actually it does i just found out. I looked at a pcb and it has vga output as well as a usb connector. I have no idea what the usb would be for though. I have this game and it has a sharp image monitor. I have no clue if its standard or medium res.
« Reply #8 on: February 08, 2008, 07:23:13 pm »
www.gamefaqs.com
move lists/faqs/codes for everything
berlincam86
« Reply #9 on: February 08, 2008, 07:28:30 pm »
Yea thats good but im actually looking for the cards that go on the tekken tag arcade game that tell you the moves or a picture of so i can print it..
Bleagh
  • Last login:October 18, 2016, 04:33:25 pm
    • BLEAGH!
« Reply #10 on: February 11, 2008, 04:31:14 pm »
Those vga outputs are med res(24hz I think) not high res(31hz or 640x480), you can get standard res through the jamma harness.  The usb port is for the controls I/O.  You can just use the jamma edge for controls tho, but you can only access the jvs settings in the menu if you have an I/O connected.
« Last Edit: February 11, 2008, 04:36:06 pm by Bleagh »
