Author Topic: NEBULA and MALA question  (Read 3651 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: February 04, 2008, 03:48:42 pm »
Can  NEBULA run in MALA?
unclet
Re: NEBULA and MALA question
« Reply #1 on: February 04, 2008, 03:52:27 pm »
I would think any emulator which can be started manually in a command window can then be ported into a frontend such as Mala, AtomicFE, GameLAuncher, MameWah, etc.. with no problem
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« Reply #2 on: February 04, 2008, 05:03:17 pm »
It can be run but you may run into issues with exiting Nebula as it doesnt use esc. to exit.  You may have to use the exit hook in mala or another prog to help with this.
I don't have it installed on my cab yet but I do on my notebook and when it exits is messes with my resolution so you may exp. issues.
BORIStheBLADE
« Reply #3 on: February 04, 2008, 08:21:50 pm »
so if I just stick with using NEBULA on its own how do I setup the rom directory?
kegger
« Reply #4 on: February 05, 2008, 12:53:42 pm »
You Put the Roms in a folder called "roms" inside the folder for the emulator. Or you can tell Nebula where they are using the "other" option in Nebula.
"C:\Nebula\roms" is the easiest..
I am going to txf them to my cab now to test..
