Author Topic: TRON joystick  (Read 2402 times)
yukonblaze
  • Last login:February 16, 2023, 11:32:48 am
TRON joystick
« on: February 04, 2008, 10:35:33 am »
Replacing leafswitch oin joystick and found the coiled wire housing the two wires to be broken.  Is this necessary to be there or can it be replaced with standard wirte wrap?
Hoopz
  • Intellivision Rocks!
Re: TRON joystick
« Reply #1 on: February 04, 2008, 12:31:03 pm »
Standard wire should be fine.  I have a Tron wiring harness if you want it.  I re-wired mine recently and don't have a use for it.
yukonblaze
Re: TRON joystick
« Reply #2 on: February 04, 2008, 01:50:43 pm »
I am actually asking about the 'spring' looking thing going from switch, through joystick, to the connector.  I was wondering if I could remove the 'spring'.
THanks
Hoopz
Re: TRON joystick
« Reply #3 on: February 04, 2008, 01:54:12 pm »
Sorry, I misread your post.  No, you don't need it there.
