Author Topic: can you find my wiring mistake?  (Read 1742 times)
specksynder
  • Last login:February 20, 2011, 05:31:31 pm
« on: February 03, 2008, 12:19:01 am »
So I wired up on control panel on my cocktail cabinet and fired up the pc to see if it worked.  I'm using I-Pac and a mag-stik plus.
Fire up the game, and everything is backwards, so I swap wires.  Game works.
Exit to windows and try to shut down, but in the drop-down menu the menu selection is scrollling as if an arrow key is pressed down.
Did I wire the joystick to normal closed instead of normal open?  Is that why it seemed to be wired backwards?
I used the terminals farthest from the ground.
  • Last login:January 26, 2026, 02:56:43 pm
Re: can you find my wiring mistake?
« Reply #1 on: February 03, 2008, 12:25:13 am »
Sounds to me like you've wired it to the wrong post
specksynder
« Reply #2 on: February 03, 2008, 12:40:45 am »
Alrighty then.... now I need to double check my buttons -- they may be miswired too.  Bummer, but better to know now.
Thanks, dudes.
somunny
  • Is it hot in here?
« Reply #3 on: February 03, 2008, 01:58:22 am »
My problem was that I kept wiring the directionals backwards, as in left was right, right was left and so on.  I just didn't want to accept that even though you push the stuck to the right, it's hitting the left switch.   :dizzy:
But like Lew said, it sounds like you've got the wires on the NC instead of the NO.
specksynder
« Reply #4 on: February 03, 2008, 07:28:38 pm »
yeah, that should have tipped me off... I made SOOOO sure I had the directions right, that if they were reversed then the switches were wired wrong.
I had ALL the switches wrong... don't know how I read them wrong.  Everything is much better now.  Thanks, everyone!
protokatie
« Reply #5 on: February 03, 2008, 08:53:29 pm »
HEHE! I ALMOST made the same mistake, except I was looking at the CP from the bottom side, and "accidentally" wired left and right "backwards". Turns out my "mistake" was correct! I had made sure to pay attention to "top vs bottom" and didnt have to worry about those being inverted!
« Reply #6 on: February 03, 2008, 10:10:14 pm »
eesh...
I don't even look what direction I'm wiring things anymore. I just fix it in Mame.
Kevin Mullins
    • Me on Myspace
« Reply #7 on: February 03, 2008, 11:56:42 pm »
eesh...
That's all fine and dandy until you go to work on a real arcade machine in which you don't have that option.  ;)
