Author Topic: Menards Cheap Tool Shop Routers  (Read 9118 times)
IG-88
« on: January 26, 2008, 11:32:26 pm »
I saw this "Tool Shop" router yesterday at Menard's that is a plunge type, has 1/4" & 1/2" collets, 12 bits, and a 100% replacement guarantee. $64 for all. Worth it for small jobs or should I save up for a Ryobi or Bosch or something? I have seen those more expensive brands at pawn shops but who knows what you are getting at those places....
I won't be using it all that much, mostly for t-molding and maybe a trackball/joystick or 2. I keep going back and forth on what to do.... :dunno
-HarumaN
sstorkel
  • Last login:November 08, 2011, 09:04:03 pm
Re: Menards Cheap Tool Shop Routers
« Reply #1 on: January 27, 2008, 07:44:49 pm »
Sounds like it's probably a piece of junk to me. If you don't mind buying junk, you'd probably save some money by going to Harbor Freight...
IG-88
« Reply #2 on: January 27, 2008, 08:02:36 pm »
Ya, I'm sure it's junk. It's the 100% guarantee that keeps me a-thinking about it.....And It's should at least work for my minor stuff.
-HarumaN
sstorkel
« Reply #3 on: January 27, 2008, 08:12:30 pm »
Probably. Just make sure you buy one that doesn't have much runout. It would suck to route your entire cabinet for T-molding, then find out that the router was spinning your bit slightly off center and had turned your 1/16th-inch slot into 3/32nds or 1/8th. In that case, I'm sure Menards would give you another router, but they probably won't pay for all the wood you ruined...
