Author Topic: Want to add joystick but not enough inputs on my ipac left. What about optipac?  (Read 1309 times)
Otto
  • Last login:January 30, 2008, 06:04:46 pm
I wanted to add a 4-way joystick to compliment my two 8-way joysticks, but I only have the ipac2 board, which only has two open inputs available. On my optipac I have two open spots for additional trackballs or spinners but I don't know if it's possible to connect a joystick to an optipac?
Any suggestions?
Thanks.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Wire the 4-way to the same inputs at your player 1 8-way.
Working: Not Enough
Projects: Too Many
Progress: None
unclet
Exactly what CheffoJeffo said   :applaud:    no additional ports required.
You would then be able to use your 8-way and 4-way joystick to go UP/DOWN/LEFT/RIGHT for the same game at the same time but only the 8-way will allow you go into the diagonals.
Otto
Cool I'll set it up that way. Thanks! :cheers:
