Author Topic: Another T-Molding question  (Read 1140 times)
mj147
  • Last login:November 10, 2024, 08:04:14 pm
« on: May 16, 2003, 03:15:41 pm »
Sorry Im sure this topic has been covered before but I was unsuccesfull in finding it  :(
I just received my t molding and after test fitting it I noticed its a hair (literally) wider, using 3/4 T molding on  3/4 birtch ply. Is this common, if so do trim off the excess? On my  sega made cab the t molding is flush with the side, but doest look like it was trimmed.
Any help/advice would be appreciated
mj147
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
Re:Another T-Molding question
« Reply #1 on: May 17, 2003, 01:08:07 am »
Is it overhang just on one side?
If so you didn't have the slot cutter centered.
If it overhangs on both sides I would tend to leave it , Unless your putting molding around your C-panel  then it might need to be trimmed.
                        Slug54
mj147
« Reply #2 on: May 17, 2003, 12:17:27 pm »
Aye it overhangs  just a hair on both sides, just wasnt sure if this was the norm and I have to trim it or not.
mj147
IIOIOOIOO
  • Last login:August 04, 2003, 02:18:12 pm
« Reply #3 on: May 17, 2003, 12:30:14 pm »
Pretty sure they sell a device to fix this. You clamp it on both sides, and zip it up and down the t-molded rail. Think i've seen one on T-Molding.com
