Author Topic: NullDC iso creator?  (Read 3381 times)
Lilwolf
NullDC iso creator?
« on: January 19, 2008, 03:17:12 pm »
I have a bunch of burned dreamcast games that I used to use in my dreamcast (when it was in an arcade machine).
I finally got around to trying nullDC and it plays my favorite two games PERFECT!  So now I want to add it to may arcade.  So I tried to create an .iso/.nrg file from the burned CD.  I don't have alcohol120 any more but I could probably find it again.   Anyone know a program that will create a workable file that works will nullDC?  I tried UltraISO creating a .nrg file, but that didn't work.
Also, anyone know if there are command line arguments to get it full screen and just playing based on the iso name?  Or a wrapper?
metahacker
  • Last login:January 17, 2024, 03:09:39 am
Re: NullDC iso creator?
« Reply #1 on: January 20, 2008, 05:14:15 pm »
try DiscJuggler?
also games will need to be self-bootable to work in NullDC.  you can use something like exoboot to do this.
there are various nulldc wrapper scripts out there.... check out http://gameex.info some have been posted there that you can adapt....
the premise of my own wrapper script is to run daemon tools to mount the image, run nulldc and unmount when its done.. it also runs nomousey.exe -hide before running nulldc to hide the mouse pointer...and runs it again to reenable it... and also does "pskill" (kill process command from sysinternals guys) for the various daemon.exe,nulldc.exe in case things get hung up.
and full screen can be enabled by default in nulldc.. u just need to edit the .ini file .. its pretty simple altho the setting appears in 2 places, only 1 is used depending on your config.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #2 on: January 20, 2008, 05:18:54 pm »
See this thread on full screen and how to specify the iso name, no wrapper required:
http://forum.arcadecontrols.com/index.php?topic=75337.0
