Author Topic: installing mame0122s for the first time...HELP!!!!!  (Read 1184 times)
Arcade Freak
  • Last login:March 27, 2008, 01:12:06 pm
« on: January 17, 2008, 07:46:25 am »
Good mornings folks,
i d/l mame122s (latest vers) yesterday and then tried to install it but it did not work. I tried d/l both the exe file and the 7z file. tried both and they are both giving me the same problem. The file d/l's no problem but then when you extract it it does not create a exe file to be able to execute the program.
Can some one shine some light on the situation?
My goal is to setup mame with mala as FE.
Cheers, :cheers:
claude
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: installing mame0122s for the first time...HELP!!!!!
« Reply #1 on: January 17, 2008, 08:23:07 am »
Did you download "MAME 0.122 Windows command-line binaries"? (6625 KB)
I have just tried it and it is fine. Amongst other files, in the root of your extraction file, there should be mame.exe. Because you mention Mala, I assume that you are aware this is the command-line version?
2600
« Reply #2 on: January 17, 2008, 08:23:27 am »
You are downloading the source code.  You need to download the binary release.
Arcade Freak
« Reply #3 on: January 17, 2008, 08:40:21 am »
ok...
thank you very much...i just check again and i guess i over looked that binary d/l aera at the bottom...i guess i got excited when i saw mame latest version....
i will try that tonight and see...thanks guys great appreciated  :notworthy:
cheers,
claude
