Author Topic: One button startup electrical details  (Read 1689 times)
Greenskein
  • Last login:January 16, 2008, 09:14:15 pm
« on: January 16, 2008, 09:02:16 pm »
Here's a quick plan of how you can turn on your whole cabinet with the push of one button.
Note:  Not shown in this file, but for the actual "On" button, I usually take apart the PC faceplate, and extend the wiring that goes from the start button to a new button that I locate somewhere out of the way on the cabinet (like on the top, or on the bottom of the CP).  Another helpful item is to also extend the PC's "reset" button so that if mame or your pc ever hangs somewhere, you can easily reset the PC without opening up the cabinet....
Zalm
  • Last login:October 10, 2010, 11:18:18 am
Re: One button startup electrical details
« Reply #1 on: January 16, 2008, 11:18:41 pm »
Thanks dude - i've been hunting for this for a few weeks now.  Do you have a part number for the 12V DC Relay?
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #2 on: January 17, 2008, 06:59:48 am »
You should use those pics and do a write up on instructables...
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« Reply #3 on: January 17, 2008, 09:26:42 am »
Here is a relay you can use
http://www.grainger.com/Grainger/items/1YDH9
and here is the socket that goes to it. Use the socket it is safer that crimping or soldering to the bottom. Contacts are rated at 10 amps which is plenty for everything for an arcade cab.
http://www.grainger.com/Grainger/items/5X852
emerica
  • Last login:September 18, 2024, 09:27:07 pm
  • Goodtimes!
    • My ongoing projects
« Reply #4 on: January 17, 2008, 12:55:37 pm »
This is very similar to the spystyle power strip. I ended up using the spystyle tutorial for my cab instead of buying the bits limited strip.
Here is the link http://spystyle.arcadecontrols.com/01/index81.htm
I saw the best minds of my generation destroyed by madness, starving hysterical.
