Author Topic: CPU choice  (Read 1528 times)
Darq
  • Last login:May 01, 2012, 10:30:55 pm
  • Darq Control
CPU choice
« on: January 13, 2008, 02:16:06 pm »
I have access to a P4 2.4 or 2.8 or an athlon 3400+.  I'm trying to piece together the comp for a mame system.  Just curious if one is better than the others?
I'll have to get a mobo regardless so would it be better just to pick up a barebones cpu/mobo combo instead of trying to recycle the older cpus?
Thanks guys.
clickhea
  • Last login:August 09, 2019, 07:33:40 am
Re: CPU choice
« Reply #1 on: January 13, 2008, 02:30:53 pm »
pentium vs athlon is an on going debate, you have your pentium lovers and you have your haters
athlon had the lead back in the day, but from what i remember reading recently pentium has the market right now.
Re: CPU choice
« Reply #2 on: January 13, 2008, 05:30:16 pm »
They are all about the same.  However, since you don't have the MB yet, I would research to see which ones use the DDR2 ram which is dirt cheap now.  I got mine from Tigerdirect.com and after rebate it came out to $40 for 2 GB or DDR2 ram!  DDR is more expensive so try to avoid motherboards that have that.
So, in a nutshell, I would compare both Intel Motherboards vs. AMD motherboards and then come up with the better of the 2 based on the ram.
~ D
Cero21
  • Last login:February 23, 2016, 11:04:44 pm
Re: CPU choice
« Reply #3 on: January 13, 2008, 06:58:28 pm »
An athon 3400+ is roughly equivalent to a P4 3.4 Ghz.  Therefore go for the athlon.
Re: CPU choice
« Reply #4 on: January 13, 2008, 08:17:20 pm »
I went to Tigerdirect.com and here's what I bought (all for about $200 after rebate)
-  AMD Athlon X2 (dual core) 4000+ (1000 mhz FSB)
-  Mini ATX Socket AM2 Motherboard with on board audio, on board Nvidia video with PCIe for upgrading
-  2 GB of DDR 2 Ram (800mhz)
-  Mini ATX case with power supply included
I already had a hard drive which I bought for $50 (160 gb)
It runs like a champ!
The AMD 4000+ chip costs $69.99.
~ D
