Author Topic: Trackball Mounting Plate  (Read 1529 times)
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
« on: January 10, 2008, 08:33:47 pm »
Does anyone know how thick it is? I was just wondering because i plan to make it flush with the rest of the wood.
Thanks,
Xb0x3r
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: Trackball Mounting Plate
« Reply #1 on: January 10, 2008, 08:47:04 pm »
Well, the thickness varies a bit on the orange peel one.  Best to wait and measure the one you're going to use.
Best,
 - Mike -
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: January 11, 2008, 02:11:33 pm »
Like pcb, it depends.  Usually about 1/16" (3/64" to 3/32"), but wait until you get your mounting plate.  Then rather than measuring the thickness with a ruler, just put your plate on a flat surface, and adjust your router so its body rests on the plate and the bit rests on flat surface.  Perfect depth.
Robin
Knowledge is Power
