February 01, 2026, 11:19:35 pm
I've never hooked up volcano buttons...Although, I've had good luck using regular sized quick connects on small pins.You might have to adjust them with a pliers a little for a good friction fit.In other words, just use half of a quick connect pinched with a pliers.
That's what I did with mine.Since then I have seen 3/16" QDs at Radio Shack, so smaller ones do exist if you want to go to the trouble.
