Author Topic: Problem entering mame config mode  (Read 1065 times)
sdrob04
  • Last login:February 18, 2021, 02:12:50 pm
« on: December 24, 2007, 10:21:38 pm »
Okay, I screwed up big-time and deleted the 'enter' option while trying to add configuration functionality to a button on my cp.  Now I cannot enter the config mode in mame at all, as I believe the current command is set to 'None'.
I've searched the forum and mame.net but can't seem to find how to start anew with a default mame configuration file.  Can anyone point me to the correct post or description on how to recover from this mistake?
Thank you...
headkaze
  • 0x2b|~0x2b?
Re: Problem entering mame config mode
« Reply #1 on: December 24, 2007, 11:23:32 pm »
delete cfg\default.cfg
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: December 26, 2007, 12:44:43 pm »
Or you can open that same file, and delete the UI_SELECT part.
There's a FAQ over at MameDev, just replace "tab"/"UI_CONFIGURE" with "enter"/"UI_SELECT".
Robin
Knowledge is Power
