Author Topic: Stuck switch message on Joust  (Read 1548 times)
Donkman
  • Last login:June 17, 2008, 05:23:25 pm
« on: December 23, 2007, 01:48:58 pm »
 I have a Joust cocktail I have begun working on to fix some existing problems.
 I have removed the leaf switch joysticks cleaned the contacts and fixed some minor problems with the pivot pins. The joysticks are working but the 1 player joystick control is coming up with a stuck switch message on the adjustments screen.The joystick is functioning normally and not stuck.  The game is playing fine on player 2 controls so I am looking for ideas on which area of the wiring harness and or pcb to examine first for the error.
kjoel0123
  • Last login:January 07, 2012, 09:57:19 am
  • Cabs for sale - Please see my flickr page for all
Re: Stuck switch message on Joust
« Reply #1 on: December 23, 2007, 02:39:53 pm »
where on joystick 1 is it stick, what direction? You can always take another wire that is wired to lets say the left side or right side of the stick just to test the wiring/stick. Check your connectors as well to the joystick. You can always replace the leaf pins on the stick. They are very cheap. Aree the conneciton soldered? If so then reflow the connections.
Dedicated Cabaret cabs I currently own:
Neo Geo/ GT Complete/Mspac galaga reunion
full size cabs: Playchoice 10 Single Monitor/Nicktoons Racing/Junior King Cocktail/ Super Punchout/
Pins- Revenge From Mars/ Black Rose/ LW3
For Sale/ Trade: Digdug in Ireland Cab/83' Chexx Hockey/Battlezone/PC10 Bartop with 6 games
Check out http://www.flickr.com/kjarcade <--not updated
