Author Topic: Subwoofer in Cab, or outside  (Read 4218 times)
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« on: May 13, 2003, 02:26:46 pm »
I know this has been tackled before but I've got an 8" Sub on my logitech speaker system.....I dont know if just leaving it in the cab will make it sound too BOOMY, or if its smarter for me to mount it outside, OR have it fire out ofone of the sides of the cab.
Opinions?
".....its like a Koala crapped a rainbow in my brain!"
BobA
  • What Me Worry?
Re:Subwoofer in Cab, or outside
« Reply #1 on: May 13, 2003, 05:48:37 pm »
I just built a jukebox with the subwoofer in the cabinet.  It is large compared to the overall size of the cabinet and at high volume tends to vibrate the backpanel of the cabinet.  The complete area in front of it is open and covered with cloth but it moves alot of air.  I think I can cut down on the vibration by driving more screws and using some deadening material but it is extra work.
I would try it in your cab and see if it causes bothersome vibrations before commiting to mounting it permanently.  My guess is that the subwoofers are designed to sit in open air.
Druin
  • Last login:May 10, 2009, 02:30:37 am
« Reply #2 on: May 13, 2003, 06:53:19 pm »
Opinions?
If it causes vibration in the cabinet but it would be preferred to keep it concealed ideally, why not port it through the back of the cabinet so it's blowing out the back, and can be exposed or cloth covered either way and not take from the look of the cabinet from the front
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
« Reply #3 on: May 13, 2003, 07:05:13 pm »
it's probably different for every cab and sub combination - i say, try it in the cab, if you don't like it, move it out of there...
...short but sweet answer (which is unlike me :P )...
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #4 on: May 14, 2003, 12:27:07 am »
Ive got the creative inspire 2.1's. SPeakers mounted behind the marquee, sub in the bottom rear of the cabinet. The sub's got an adjustable level control so I fired up asteroids, held down thrust, and turned the sub down when the cabinet stopped vibrating. It's stil la little heavy in some games but I typically play it loud anyway so it blends nicely, and for WinAmp Ive got the EQ tuned to drop some of the bass.
If the sub's not adjustable, there may be a software/driver way to adjust the sub output, otherwise yeah, you can try going out a hole in the back
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #5 on: May 14, 2003, 07:43:44 pm »
Opinions?
In the cab.  The cab itself will help resonate the base, effectively making it louder and potentiall deeper.  My cab was full of vibrations when I first through the sub in.  But I found the trouble spots, one by one, and secured them so that vibration wasn't possible.  End result?  No vibrations.  Garunteed you will have vibrations when you first put the sub in, though.  But you can work through it :)
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
