Author Topic: wanted medium res 19 inch monitor, or how can I use an lcd to receive EGA signal  (Read 1629 times)
insurancedad
  • Last login:December 20, 2007, 04:40:51 pm
Hi, I need a new if possible 19 inch med res monitor, or if someone can tell  me how to use a lcd computer monitor,and or which one , will accept the EGA signal, from a Crusin USA board.    Even a scan converter would be good.  Any help....thanks,,,email,       insurancedad@netscape.net
SavannahLion
How much are you willing to spend?
insurancedad
email or call, 563 260 1976 , insurancedad@netscape.net    ,.  and let me know your price,,,I dont expect anyone to give one away.  Im in Iowa,  Thanks,,Mike
ahofle
    • Arcade Ambience Project
insurancedad
Thanks,,I will check their prices,,If anyone knows how to use a computer lcd,,let me know too,
insurancedad
yeh, checked these guys out and they dont have these 19 inch med res monitor anymore,,,anyone else know of any sources????  or again,,how to wire up a computer lcd type,,or even who might have a scan converter board
ahofle
Billabs has some multisyncs (both LCD and CRT) that should handle EGA:
http://billabs.com/monitor_select.htm
19" CRT:
http://billabs.com/bl19c91t.htm
19" LCD:
BL19LB0H on this page: http://billabs.com/lcds.htm
One word of warning though, I believe someone around here tried that CRT multisync as a Paperboy (also EGA) replacement and never got it to work.  There is a thread somewhere in the monitor forum about it.  Also don't expect too much technical assistance from Billabs.
insurancedad
thanks,,I want it to run a cruis'n usa board,,Ive built serveral into mini cabs, using some new neotec 19 inch I stumbled on a few years back,,but need some more.
