Author Topic: Millipede power supply problems  (Read 2605 times)
shilmover
  • Last login:September 25, 2018, 12:36:59 am
« on: December 18, 2007, 11:30:29 am »
Got a Millipede yesterday and it has some issues.  When I power it up, the screen displays random characters.
According to the seller, its a power supply problem not sending enough power to the PCB and that I should change out the Cap and Voltage Reg.
Can anyone comment on whether that could cause it? or is it a bad board?
My projects...
Finished:  Stargate (only 'cause I got it that way)
In progress:  Tron, 48-in-1 for School Auction, DKJr (currently a 60-in-1), Millipede, MAME System
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
Re: Millipede power supply problems
« Reply #1 on: December 18, 2007, 12:16:53 pm »
Could be power supply, could be bad connections, could be a board problem.
Probably should measure the voltages at the game board edge connector before making any assumptions.
D
Level42
« Reply #2 on: December 18, 2007, 12:37:12 pm »
Is that screen completely static ? If so, it reminds me a lot of my first Centipede issue.
(http://forum.arcadecontrols.com/index.php?topic=63654.msg753810#msg753810)
My suggestion is to first check the voltages on the PCB. There are lots of testpoints where you can measure them. If these are OK, try to short one of the +5V test points to the reset pin of the 6502 (pin 40) and see if it runs then.
shilmover
« Reply #3 on: December 18, 2007, 05:14:27 pm »
Yup.  Its static.  Nothing changes.  Just checked your post and its identical to mine!!!  how did you get a picture of my cab?!?   :angry:  >:D
I will check the voltages tonight.
« Last Edit: December 18, 2007, 05:16:15 pm by shilmover »
My projects...
shilmover
« Reply #4 on: December 18, 2007, 10:12:36 pm »
Rebuilt AR board.
GND to +5v = 5.18-5.21V
GND to pin 40 of 6502 = 4.78-5.08V
My projects...
Level42
« Reply #5 on: December 19, 2007, 01:26:32 am »
OK, so the power is OK, reset line is OK too....
Does anything happen when you push (and hold) the reset button ?
shilmover
« Reply #6 on: December 19, 2007, 12:43:24 pm »
I do not see a reset button on the board.  Where is it on the centi?
My projects...
Level42
« Reply #7 on: December 19, 2007, 02:56:35 pm »
On the wrong side....no really, I'm serious, it's all the way at the end you have to reach in completely. It doesn't look like a button, more like a disk-like object. It feels like it doesn't do anything, but it sure does. At least, this is all true for the Centipede.
shilmover
« Reply #8 on: December 19, 2007, 03:53:02 pm »
Didn't see one, but will look again.
My projects...
