February 17, 2026, 07:26:45 pm
anyone recommend a raid card for sata2 drives?
Quote from: squirrellydw on December 16, 2007, 11:47:42 amanyone recommend a raid card for sata2 drives?Check out http://www.3ware.com - I've not personally used 'em, but know a few folks who swear by 'em.
Mirroring using the onboard controller is fine, as long as the onboard controller doesn't fail. What do you do then?
Quote from: boykster on December 17, 2007, 03:42:58 pmMirroring using the onboard controller is fine, as long as the onboard controller doesn't fail. What do you do then?Stick the disk(s) in another computer. Heck it would even work in a simple external housing and these are dirt cheap.
Not all 'mirrored' volumes are just plain old regular volumes....
