Author Topic: Ultimarc's U360's mapping Issues totally confused... trying to set up and enjoy.  (Read 1511 times)
mrclean
    • Guscade
I don't exactly know what the deal is but the ultimarc U360s will only let me map it once in other words in the test pattern I can only choose one of the 10 choices to download to the stick, once I pick it that's it, What am I doing wrong? in other words if i pick the 2-way map and download it to the stick within MaLa / any front end I can only scroll up and down.. it won't let me jump to different letters.. etc.. Currently I now have it dedicated as an 8-way what the heck is going on? How can i download ALL the maps to work with MaLa Ive read all the wiki's and FAQs and still can't figure it out so confused and also MaLa's plugin made by fatfingers in the umapper.log file said this :
_run_ultramap: Failed to create process '"ultramap.exe" "C:\Program Files\mala\Maps\mala.ugc"': error 2
2,370,650 Gun.Smoke
fatfingers
  • Got UltraStiks?™
I replied in your other thread about the ultramap issue from the plugin.  Please see there for resolution.  Also, in Mala you will almost definitely want to be using a 4-way map, which is the default map applied by the plugin.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
