Author Topic: What version of MAME should I be using?  (Read 6453 times)
Jop
  • Last login:April 03, 2011, 04:20:24 am
« on: December 05, 2007, 05:39:30 pm »
Hi, sorry if this question has been asked many times before... but I have tried looking!
What version of MAME would work best with the PC I'm going to use in my project? Specs below:
P4 1.7ghz
384mb RAM
geForce 2mx
Green Giant
Re: What version of MAME should I be using?
« Reply #1 on: December 05, 2007, 06:06:49 pm »
Have you tried running some games with the latest version?  I think what you have can handle it.
Toxic Arcade, my first build
Lilwolf
« Reply #2 on: December 05, 2007, 08:37:33 pm »
The latest version of mame will be able to run 98% of all the games out there.
And if you find the fastest version of mame, you might get 100 more games running.
Fastest version is v.36 (or so) when they moved off 8bit color.  But you will loose 1000s of games
Then .58 had a descent slowdown
But, all in all... get the latest mame, and a frontend that allows more then one version of mame... then try others and see if you can get a few more games running?  why not.  (I do this when you want to play a game that the latest mame has broken..)
TOK
  • The Game Always Wins
« Reply #3 on: December 05, 2007, 09:50:43 pm »
While I have later versions for specific games, my favorite version of MAME is .99.
Its faster than the .1xx versions, Highscore.dat is still supported, the Robotron speed issue was corrected, and all of the MAME'd Golden Tee games are in there.
I'm running .99 on both my cabs, with similar specs to yours. One is a 2ghz Pentium 4, the other is a 1.9ghz Athlon XP.
Anubis_au
  • Last login:January 15, 2023, 10:12:32 pm
  • Ever danced with the Devil in the pale moonlight?
« Reply #4 on: December 05, 2007, 11:44:22 pm »
What about running a newer romset on an older version of MAME?
I have the full romset for v1.18, but all I want is to play the classic arcade games (pacman, galaga, bombjack, wonderboy etc).
Is it better to play these with MAME v1.18 or newer, or with an older version, like v0.99 as TOK suggested?
Or is there some app that 'downgrades' the romset accordingly to the MAME version. If so, is there any benefit to this?
SGT
  • Last login:Yesterday at 07:39:32 pm
« Reply #5 on: December 06, 2007, 12:12:21 am »
You can get a "rollback" set of roms which will allow you to take your .118 set and create a set that will work for any older version of Mame. You do this by using a utility such as clrmamepro.  You will definitely see a performance improvement with an older version such as .99.
« Last Edit: December 06, 2007, 12:14:04 am by SGT »
Anubis_au
« Reply #6 on: December 06, 2007, 10:19:12 pm »
How noticeable would this performance improvement be? Also, what's the reason why these old games would perform less well with newer MAME releases? Surely by now, these old games have, for the most part, been 100% emulated and are unchanged through the versions of MAME?...
SGT
« Reply #7 on: December 06, 2007, 10:55:55 pm »
For one thing, there was a major change in the video portion of the mame code around version .106 or .107.   As Mame is enhanced, more powerful computers are needed to run it.  And again, it depends on which games we're talking about.  Some games will run just fine with the newest version of Mame.  Don't take my word for it.  Do your own tests.
Anubis_au
« Reply #8 on: December 06, 2007, 11:18:31 pm »
I've a hyperthreaded P4 3.2GHz with 1gig RAM. It should be able to run old games at 100% speed.. should.
SGT
« Reply #9 on: December 06, 2007, 11:39:30 pm »
I have the same P4 at 3.19 Ghz with 2 GB of ram.  There are still some games that I prefer to run version .100 with.  Ideally I want a Core 2 Duo clocking close to 4 Ghz with 64 bit Mame running on 64 bit Vista.  That will run a lot of the more demanding games.  There's a thread on the main forum about it.
elvisart
  • Last login:September 16, 2010, 02:53:43 pm
« Reply #10 on: December 08, 2007, 01:51:13 am »
Why would anyone run Vista? It's a proven memory hog!
If I wanted a stable 64 bit OS, I'd use XP 64 or the latest
64 bit Linux OS.
Haze
    • MAME Development Blog
« Reply #11 on: December 08, 2007, 09:48:52 am »
Best 64-bit platform for MAME right now is a 64-bit Linux distro with SDLMame.
Vista just takes too much effort reconfiguring to be 'not annoying' to be worthwhile, XP-64 has bad driver support.
Given the lack of what I would consider a viable 64-bit Windows platform I'm seriously considering switching my day-to-day OS to Linux.  I've tried the recent Ubuntu distributions briefly and they're *very* good.  Something I've definitely not been able to say about Linux before.
SGT
« Reply #12 on: December 08, 2007, 11:08:36 am »
64 bit Linux OS.
The best options are Linux or Vista because as Haze pointed out, driver support is so bad with 64 bit XP.  Then you get into which you had rather do, pare Vista down so that it runs well, or learn Linux.  The driving factor for me is that I run a lot more than Mame on my machine which will make the choice "Vista" for me.
Red
  • Last login:November 07, 2017, 08:37:51 am
« Reply #13 on: December 08, 2007, 05:34:55 pm »
"The best options are Linux or Vista because as Haze pointed out, driver support is so bad with 64 bit XP.  Then you get into which you had rather do, pare Vista down so that it runs well, or learn Linux.  The driving factor for me is that I run a lot more than Mame on my machine which will make the choice "Vista" for me."
Would it be best then to just install Vista Basic 64, so you don't have to worry about all the bells and whistles of the other versions of Vista bogging down your system?
SGT
« Reply #14 on: December 08, 2007, 06:09:50 pm »
Red,
I am assuming you have a Core 2 Duo?  Have you seen the thread linked below?  Taz-Nz's benchmarks show excellent results with Vista.  You might PM him to see if he did anything to optimize Vista and see what version he has.  I'm not sure what the results would be for a 64 bit processor other than the C2D.
http://forum.arcadecontrols.com/index.php?topic=72776.0
Red
« Reply #15 on: December 08, 2007, 06:12:22 pm »
Will do.  Thanks SGT.
Red
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #16 on: December 09, 2007, 04:51:37 pm »
I agree with some of the above posts.  If you're on even a Pentium 4 or above, try using the latest version of mame and make sure all the games you want to play will work... fix the ones that don't and then stay there until a reason to upgrade comes along.
I'm running v.118 and even though upgrading to the latest version of mame is trivial (replace files), auditing the games you enjoy and having to find updates for the games that no longer work because of one update or another, is time consuming.
so in short, use the latest version and upgrade if there's a feature you've gotta have.
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
