Author Topic: Is it possible to hook this monitor up to a computer?  (Read 2192 times)
unclet
« on: November 28, 2007, 11:01:43 am »
I have no real "monitor" skills to speak of but I do know how to solder wires and stuff.
I am trying to locate a small LCD monitor to use in a portable Mame cabinet which am I thinking of building.   The largest size of monitor which would fit for me would be about 10".   As a result, I searched Ebay and found the following LCD monitor available:
http://cgi.ebay.com/SHARP-10-Monitor-LCD-Panel-LM80C032-TV-Screen-74H0620_W0QQitemZ180184515874QQihZ008QQcategoryZ51161QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I am wondering how easy/hard this would be to connect to a computer system?  Is it a simple matter of connecting wires from this 10" LCD monitor to the VGA output port of the computer ...... or is it a lot more painful and not worth pursuing?
shardian
Re: Is it possible to hook this monitor up to a computer?
« Reply #1 on: November 28, 2007, 11:27:28 am »
Please note that the ebay link you provided is simply an lcd panel without a controller board. It is basically useless without a controller board.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: November 28, 2007, 11:43:52 am »
Yeah, it just states that it "Refurbished" .... but doesn't clearly state whether or not it has the controller or not.
So you may want to send them a message and ask.
And you would still need to know the full specs on the LCD and controller to determine what resolutions etc that it will handle.
But definitly a worthy project idea for sure.
« Last Edit: November 28, 2007, 11:47:06 am by Kevin Mullins »
unclet
« Reply #3 on: November 28, 2007, 12:58:12 pm »
Ok, thanks for the input .... I had no idea about the controller part ... I will ask.
shardian
« Reply #4 on: November 28, 2007, 01:19:36 pm »
Its a laptop replacement panel, thus it definitely does not have control board.
Kevin Mullins
    • Me on Myspace
« Reply #5 on: November 28, 2007, 03:49:16 pm »
My mistake.
I was thinking of the inverter and all that.
I've seen laptop LCD's and such listed that "come with controller"..... but I guess it would just be sitting externally then when you recieved it. (for the smaller lcd's that is)
I would imagine the larger desktop PC versions would have the controller built in though. (?)
unclet
« Reply #6 on: November 28, 2007, 04:05:58 pm »
Ahh .. ok then .... thanks.
Hey .... does anyone know where to get a cheap 10" LCD screen which can be hooked to a PC?
