Author Topic: Mapping zincs inputs to joypad?  (Read 4650 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: November 26, 2007, 11:41:03 pm »
I haven't used zinc in awhile but I was getting around to getting it set up on my new cab which uses gpwiz49s for the control interfaces and hence the controls are seen as gamepads in windows.
I want to map my controls in zinc to reflect this but I can't figure out how to do it globally.  I know how to do it on a game by game basis using zincgui but I would like to do them all at once if possible.
It seems like I did this before but I can't remember how.   I know HowardCasto has a program that remaps the controls for zinc but it doesn't work when using gamepads.
Warborg
  • Last login:January 11, 2026, 02:46:32 am
  • Personal text? Nah...
Re: Mapping zincs inputs to joypad?
« Reply #1 on: November 27, 2007, 01:18:24 am »
I ran into the exact same thing using an Ultrastik...  And unfortunately I ended up having to just edit each games config manually...   :badmood:
metahacker
  • Last login:January 17, 2024, 03:09:39 am
« Reply #2 on: November 27, 2007, 09:22:30 pm »
there is a zinc controller plugin from a guy named winter blast.
i'm using the version of zinc packaged for use with gameex... that gets downloaded in the set up utility in the 'download emulators' tool.  it has a ZincFE.exe wrapper, and winterblast's plugin.
im using U360s.
zinc works beautifully with them, in all games i have played.
i tried setting this up (in the past) manually and i was having problems with the non-fighter type games not working properly ... im not sure if its the ZincFE or (probably this...) a newer version of the Winterblast plugin ... but now, "it just works."
so yeah... you can just use this plugin afaik.
metahacker
« Reply #3 on: November 27, 2007, 09:34:40 pm »
i think u possibly want this (front end) .. i use this to invoke the controller button set up
http://www.aldostools.com/
( or just go straight here -->  http://avargas.tripod.com/index2.html )
and u def want the winterblast controller plugin... v1.6
which i think u can get from here
http://www.emuunlim.com/cgi-bin/wwwthreads/showpost.pl?Board=retrogen&Number=79942&page=1&view=expanded&mode=threaded&sb=6#Post79942
Zebidee
  • Last login:January 07, 2026, 10:22:02 am
« Reply #4 on: November 28, 2007, 08:06:20 am »
Go to this thread
http://forum.arcadecontrols.com/index.php?topic=73330.msg761096#msg761096
Download this file (it includes winterblast's 1.6 plugin).
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=73330.0;attach=89446
It includes controller ini files to map Zinc joystick buttons o keyboard codes (for mame cabs).  You can easily edit the ini files in the /zinc/ini directory to reflect gamepad buttons rather than mame cab keyboard codes.  You still have to do it on a game-by-game basis though, as Zinc uses different buttons for different games.
Popcorrin
« Reply #5 on: November 29, 2007, 01:47:44 am »
Thanks for the info guys.  I was able to remap the controls globally with aldo's zinc frontend.
