Author Topic: Connecting a NANAO MS8-26SU to a ArcadeVGA card?  (Read 4030 times)
BMW Z1
  • Last login:May 11, 2020, 08:23:57 am
« on: November 24, 2007, 03:30:42 pm »
Hi Chaps,
I am just about to purchase a ArcadeVGA card, but need to know if ill need to also purchace a video amp as im not sure if the monitor uses a 1 or 4v input?
Plus do i need to connect the black and white monitor inputs together to get the composite sync?. I know where the RGB cables go, but a little confused what to do with the Black and White cables?
At a guess id say
Black goes to pin 10
White to 13 + 14
1 - Red
2 - Green
3 - Blue
4 - Monitor ID *
5 - Ground
6 - Red Ground
7 - Green Ground
8 - Blue Ground
9 - Keyway (No pin)
10 - Sync Ground
11 - Monitor ID *
12 - Monitor ID *
13 - Horizontal Sync
14 - Verical Sync
15 - Monitor ID *
Zebidee
  • Last login:Yesterday at 01:21:22 pm
Re: Connecting a NANAO MS8-26SU to a ArcadeVGA card?
« Reply #1 on: November 28, 2007, 07:26:48 am »
Think about the video signals coming FROM the PC -> monitor.
You'll need to attach ALL grounds to the monitor's black lead (assuming that is ground).
northerngames
  • Trade Count: (+18)
« Reply #2 on: November 30, 2007, 10:50:29 pm »
get the ultimarc video amp
connect your vga cord to it from the pc
coonect rgb rom monitor to rgb on the amp
H your white wire goes into H  on the amp.
your blue wire with white stripe is the ground wire and goes to the ground on the amp.
v is not needed becuase the amp already combines it.
I have this monitor also  :cheers:
Zebidee
« Reply #3 on: December 01, 2007, 01:36:42 am »
Every manufacturer uses different coloured wires in their cables, so use a multimeter to trace it back to your VGA pins.
I once used a VGA cable the had green wire=red, brown wire=green and yellow wire=blue.  Sync could be any colour.  Ground could be any colour, but more likely to be black.
You need to feed a composite sync signal to your monitor.  Twist your H & V sync wires together (pins 13 & 14 from VGA).  Some ex-VGA monitor cables combine this anyway (as the original VGA monitor took composite sync).
Kevin Mullins
    • Me on Myspace
« Reply #4 on: December 01, 2007, 11:48:04 am »
Doesn't the ArcadeVGA card already boost the pc video signal up?
I thought the video amp wasn't needed if you used the ArcadeVGA card.
Just curious........
northerngames
« Reply #5 on: December 01, 2007, 02:15:36 pm »
the ultimarc J-pac has the built in ammp the arcadevga does not have the amp build in.
also the wiring coloring I gave you above is what they are no multimeter needed.
Zebidee
« Reply #6 on: December 01, 2007, 05:41:59 pm »
Use the DMM and know what you are doing.
BMW Z1
« Reply #7 on: December 02, 2007, 10:09:33 am »
Hi northerngames, yes your wiring is correct, I just read the monitor cct diagram, and checked the RGB voltage going into the monitor at 4V each. So ill be getting an amp also. Thanks
BMW Z1
« Reply #8 on: December 02, 2007, 10:10:53 am »
Kevin, the ArcadeVGA only outputs 1volt
