November 04, 2025, 01:35:30 am
Yeah, that works, but why not just get a few 8-bit shift registers and a breadboard?
Quote from: MajorLag on November 24, 2007, 01:20:25 amYeah, that works, but why not just get a few 8-bit shift registers and a breadboard?also, even if you were into electronics it would still be easier and faster to hack the gamepad rather than make something from scratch...
You don't need to keep the SNES connector if you wire it to the parallel port and use DirectPad Pro or one of the other drivers. I guess I just don't see the need to ruin a perfectly good SNES controller.
Quote from: MajorLag on November 24, 2007, 05:19:37 pmYou don't need to keep the SNES connector if you wire it to the parallel port and use DirectPad Pro or one of the other drivers. I guess I just don't see the need to ruin a perfectly good SNES controller.That's true, but the OP never explained whether he was wiring it to a PC or to a console. If you're wiring to a PC, why bother with hacking it like he did at all?
Hi, this is what I did with it, or well, one of them so far:)Thanks HarumaN!
