Author Topic: Do you have working guncon2 lightguns (with newer mame)?  (Read 1051 times)
mattorama
  • Last login:November 28, 2007, 11:55:33 am
« on: November 22, 2007, 10:47:16 am »
Does anybody have a working guncon2 setup using a newer version of mame?
I cannot get it to work with mame 119, wingun or smog's driver.
It tracks nicely, but when shooting it flashes without registering the shot.
I have a suspicion that the available drivers and mame are now incompatible.
I did setup mame.ini with the standard lightgun 1, lightgun_device stuff.
If your setup works...
  • Which version of mame are you using?
  • Are you using wingun or smog's driver? Which version?
  • What does your mame.ini look like?
Any help is greatly appreciated?
mattorama
Re: Do you have working guncon2 lightguns (with newer mame)?
« Reply #1 on: November 26, 2007, 12:00:53 pm »
Does anyone know if wingun or smog's driver are even being supported anymore?
If not, I'm wondering if guncon2's and mame should be considered incompatible.
I still have not been able to get the latest mame to work, nor have I heard from anybody that has it working.
-M
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
« Reply #2 on: November 27, 2007, 10:53:38 am »
Two LCDTopGuns (compatible guncon2) with lastest Smog drivers works perfectly with the lates versions of mame (0.119, 0.120, 0.121).
Put lightgun=1 and lightgun_device lightgun is redundant. Use only Lightgun_device lightgun. Well, maybe you could use lightgun=1 if you want to play games like Terminator 2 with the guns.
Be sure that the mapped button to fire is something like Gun_??? (sorry, I don't remember now the correct spelling.
mattorama
« Reply #3 on: November 27, 2007, 12:40:53 pm »
Thanks for the response.
I noticed that smog has put in support for the LCDTopGuns.
 I couldn't get smogs driver to work with regular (orange) guncon2 guns. What happened to the calibrate button?
I'll try again.
-M
