Author Topic: G07-CBO, powers on, no picture.  (Read 3026 times)
Malacus
  • Last login:April 17, 2010, 12:42:16 am
  • DANCE!
« on: November 16, 2007, 06:39:13 pm »
I recently picked up a Pole Position Upright with a go7-cbo in it, i believe its a 13" monitor.
I didnt really expect anything in it to work, but the monitor shows the most promise.
When I fired up the machine nothing really happened, but i heard the monitor come on, and after waiting for a minute or so i was able to see 3 dots in the middle of the screen, now I'm somewhat color blind, but I believe they were red green and blue.
With some minor knowledge I inspected what I could without yanking the thing out of the cabinet, I noticed, pardon me if Im calling things the wrong name, the top of the Width Coil, where you would adjust it, i presume, was missing, but it was still all coiled together. There is also a crack in the Flyback, but it wasnt on the white part, it was on the 'bar' on the outside of it... sorry, i dont know what to call it...
To make sure it was getting a signal, I hooked it up to a game I know to be working.
Any help would be appreciated.  :)
-Mal
« Last Edit: November 16, 2007, 06:48:45 pm by Malacus »
~Classic Gaming Since 1983~
Ken Layton
  • Guru
  • Technician
Re: G07-CBO, powers on, no picture.
« Reply #1 on: November 16, 2007, 06:45:39 pm »
Pole Position would have a 19" not 13" monitor.
Since you don't know the history of this particular monitor, here's what you need to buy:
Capkit
Width coil
Flyback
That should get your monitor running.
Malacus
  • DANCE!
« Reply #2 on: November 16, 2007, 06:50:13 pm »
Yea, its definitely a 19"... dont know why i thought it was 13"...
Anyway, I'll try that, Thanks!
-Mal
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
« Reply #3 on: November 17, 2007, 11:34:53 am »
Capkit
Width coil
Flyback
Before you spend some dough on the monitor,  are you getting game sounds, can you coin it up and hear the game working?  Is there any indication that the game itself works?    PP boards are notorious for being dead and can be a major PIA to fix.   Also PP boards are major power hogs and burnt connections are common, keeping the game from running.
When you checked to make sure it was getting a signal, do you mean you tested the monitor with a known working game, or do you mean you plugged a known working monitor into the PP to make sure the game works?
D
Malacus
  • DANCE!
« Reply #4 on: November 19, 2007, 01:59:47 pm »
I tested it with another game, I cant really expect the PP to work straight out...
-mal
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« Reply #5 on: November 19, 2007, 03:20:57 pm »
you can bump up the brightness on the flyback and check for rastar lines...
Level42
« Reply #6 on: November 19, 2007, 05:34:35 pm »
Capkit
Width coil
Flyback
And Bob Roberts has all of this in one handy and pretty affordable kit:
http://homearcade.org/BBBB/parts.html#flyback
cw
    • The Cab
« Reply #7 on: November 19, 2007, 07:29:15 pm »
while doing the cap kit dont forget to do the sync upgrade...and reflow the input molex pins..
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #8 on: November 19, 2007, 07:35:54 pm »
Ok, here is the scoop...
You have high voltage.
What you have is no deflection,
3 dots in the center, turn the screen/G2 down or you will burn the tube.
Check to be sure the yoke, is plugged in really sounds that simple.
Good luck
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
