Author Topic: billabs monitors plug-and-play?  (Read 1780 times)
hohlraum
  • Last login:January 05, 2021, 08:40:55 am
    • Blog
« on: November 16, 2007, 11:53:18 am »
do the billabs 27" monitors communicate their supported resolutions and refresh rates to the video card/operating system like standard pc lcd/crt monitors?
TeamTEOR
  • Last login:December 14, 2018, 09:43:43 pm
  • Off to the Edge of Reality
    • My Website
Re: billabs monitors plug-and-play?
« Reply #1 on: November 16, 2007, 08:08:18 pm »
Well, my 25" flatscreen tri-scan doesn't. I had to order up an ArcadeVGA card, however when I was talking to BilLabs on the phone they told me they had monitors that did work for higher resolutions and were capable of working with a PC out of the box. Your best bet is to call them and find out what monitors they know of directly will work. TEL: +1.877.411.LABS (5227). They answer the phone quickly.
Tom
MonMotha
« Reply #2 on: November 16, 2007, 08:14:14 pm »
I've never seen or heard of an arcade monitor supporting DDC EDID (the means by which monitors communicate their capabilities to the video source), so chances are it does no, however, Billabs does have monitors which go up to 1024x768@60Hz, and include 800x600@60Hz capability, which is the default resolution of WinXP and some Linux distributions when they don't know what monitor is hooked up.  From there, you can reconfigure at will.
Also, I don't know why you'd need an ArcadeVGA at all for a trisync unless your video you had before was incapable of doing EGA/CGA modes (there was a time in there for about 4-5 years were most stuff nVidia and ATi shipped couldn't, but most stuff seems able to again).  Just boot with a PC monitor hooked up, reconfigure for 640x480 (VGA), and then hook up the arcade monitor.  You should only have to do this once.  In WinXP, the 640x480 option is hidden (go into Advanced, Monitor, List All Modes), but it's there.
hohlraum
    • Blog
« Reply #3 on: November 19, 2007, 11:49:32 am »
i recently got the billabs 4-mode 27" and installed.  it definitely does not seem to inform the card/os of its supported resolutions/refresh.
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
« Reply #4 on: November 22, 2007, 10:21:25 pm »
Is it working ok at 800 and 1024x764 resoultions? Thinking about getting one. Hows the output look?
