Author Topic: would this Sony XBR 25” Television Monitor work as an arcade monitor?  (Read 2423 times)
knave
here's pics:
I'm just not sure, it doesn't have a tuner and has some type of rgb input???
grantspain
Re: would this Sony XBR 25” Television Monitor work as an arcade monitor?
« Reply #1 on: November 09, 2007, 12:59:35 pm »
if you can get the rgb pinout it should be a great arcade monitor
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: November 13, 2007, 11:19:10 pm »
or buy/build a rgb to composite converter for using the standard video inputs,
and feed it a NTSC signal  ( 15.734khz horiz/59.9hz vert ,1vpp neg sync , 3.58mhz chroma)
qrz
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #3 on: November 14, 2007, 02:58:46 am »
Here is the RGB Pinout I beleive:
http://pinouts.ru/Home/sonyrgbmulti_pinout.shtml
knave
« Reply #4 on: November 14, 2007, 04:24:46 pm »
Ok, so If I get a connector that fits I could connect it to a jamma harness with these pins?
25 - Red Input
26 - Green Input
27 - Blue input
30 - H.sync or composite sync
Is there something I'd need to do to the signal, voltage etc?
Level42
« Reply #5 on: November 14, 2007, 04:37:22 pm »
qrz
That wouldn't be a smart thing to do, since it is completely unneccesary, costs extra money and most importantly degrades the quality of the picture a lot.
Voltages: MAYBE you need some small resistors in series with the RGB inputs, but you can safely try them to see how it looks. You also need at least one ground pin.
From the pic it looks like this is a regular header connector. You should be able to get these and use some ribbon wire. OR you can get double pin connectors that will fit these and wire-up according.
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #6 on: November 17, 2007, 05:56:13 pm »
Looking at the pinout, I wouldn't be surprised that you would need all the GNDs tied to ground.  Like pins 4,8,9,10,11,13,15,16.  Just a wild guess, though.
Good luck,
If I do not respond to your post in a timely manner, feel free to PM me.
Level42
« Reply #7 on: November 18, 2007, 03:23:57 pm »
Well, not 100% sure about that special connector, but with SCART this isn't necessary. I only tied one GND up to the GND wire from my Galaxian cab and it works fine. The multiple grounds are there for if screened cable is used. Since cab builders didn't bother to use that it's fine like I did it.
rockin_rick
« Reply #8 on: November 19, 2007, 12:33:06 am »
That's cool.  I just thought that it may have been possible that those grounds weren't connected internally - evidently they are.  :cheers:
